Feature Requests
Node based view for Audio
Joined: 5/28/2020(UTC) Posts: 53  Location: UK Was thanked: 7 time(s) in 5 post(s)
I am just wondering if you could create a Node-based view to see what audio is going where. You can also see VU meters in the Mix tabs to see levels as well.  Node based Mixing.jpg (42kb) downloaded 0 time(s).
Is that really any clearer than a matrix type display (image attached), which in effect is more like the layout of bus send buttons on a conventional hardware (analogue) mixer?  BusRoutingMatrix.png (59kb) downloaded 0 time(s).The lines on that 8-input example are already getting a bit congested in places just with 10 connections going to 4 busses (out of a possible 64). Set up a couple of mix-minuses to another two busses and it's going to get harder to see what's going where.
Hi Zen, What you are suggesting is amazing as well. Having level meters under each input would greatly help see what issues you are having. Also a button for mix-minus would be great as well for quick setup.  Screenshot 2022-11-11 at 13.43.56.png (308kb) downloaded 0 time(s).
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Feature Requests
