hadphild
#1 Posted : Friday, November 11, 2022 1:47:43 AM(UTC)
hadphild
Was thanked: 7 time(s) in 5 post(s)
I am just wondering if you could create a Node-based view to see what audio is going where. You can also see VU meters in the Mix tabs to see levels as well.
Node based Mixing.jpg (42kb) downloaded 0 time(s).
zenvideo
#2 Posted : Friday, November 11, 2022 3:21:37 AM(UTC)
zenvideo
Is that really any clearer than a matrix type display (image attached), which in effect is more like the layout of bus send buttons on a conventional hardware (analogue) mixer?
The lines on that 8-input example are already getting a bit congested in places just with 10 connections going to 4 busses (out of a possible 64). Set up a couple of mix-minuses to another two busses and it's going to get harder to see what's going where.
hadphild
#3 Posted : Friday, November 11, 2022 9:11:03 PM(UTC)
hadphild
Hi Zen,
What you are suggesting is amazing as well. Having level meters under each input would greatly help see what issues you are having. Also a button for mix-minus would be great as well for quick setup.
Screenshot 2022-11-11 at 13.43.56.png (308kb) downloaded 0 time(s).
dmwkr
#4 Posted : Saturday, November 12, 2022 12:01:05 AM(UTC)
dmwkr
