Hardware Compatibility
Acasis 4-Channel Thunderbolt3 HDMI
Hello, does anyone have experience with the Acasis 4-Channel Thunderbolt3 HDMI-compatible External Video Capture Card? Thank you
Joined: 10/27/2020(UTC) Posts: 33  Location: Porto Alegre Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: JirkaJ  Hello, does anyone have experience with the Acasis 4-Channel Thunderbolt3 HDMI-compatible External Video Capture Card? Thank you Hi, I have experience... both in working models in vMix and very well... The only issue, which I've already contacted Acasis and until today I haven't seen a solution, is the loss of frames on the "SDI 2" connection of the SDI model, and on the "HDMI 1" of the HDMI model. I don't know exactly why, but it loses some frames, which when using it in replay, you notice it very high.
 1 user thanked samirbridi for this useful post.
Oh! Just for the record, this card is just "CAPTURE", it doesn't have "output" like Blackmagic models
Thank you very much for your reply, I will probably buy the card.
Joined: 3/26/2022(UTC) Posts: 10  Location: Cumbria Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Did Acasis ever resolve this ? Thanks Originally Posted by: samirbridi  Originally Posted by: JirkaJ  Hello, does anyone have experience with the Acasis 4-Channel Thunderbolt3 HDMI-compatible External Video Capture Card? Thank you Hi, I have experience... both in working models in vMix and very well... The only issue, which I've already contacted Acasis and until today I haven't seen a solution, is the loss of frames on the "SDI 2" connection of the SDI model, and on the "HDMI 1" of the HDMI model. I don't know exactly why, but it loses some frames, which when using it in replay, you notice it very high.
Joined: 1/7/2025(UTC) Posts: 6  Location: Montreal Thanks: 2 times
Anyone else using this thunderbolt capture card? Seems fairly priced for a 4 input model.
How stable it is?
Joined: 11/2/2024(UTC) Posts: 2  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Just bought the 4 hdmi thunderbolt 3 card from acasis
All 4 inputs work, but they stutter, its almost imperceptible but for us professionals, its not reliable
It could be used for 4 static inputs, like powerpoint, but not reliable for cameras
I already asked for their support, if i cant get it to work as supposed, i will be refunding soon
 1 user thanked magoo182 for this useful post.
Originally Posted by: magoo182  Just bought the 4 hdmi thunderbolt 3 card from acasis
I already asked for their support, if i cant get it to work as supposed, i will be refunding soon Interesting to know! Did you keep it or return it? Stutter is a bummer for cameras indeed.
