#1 Posted : Tuesday, October 18, 2022 2:37:25 AM(UTC)
Originally Posted by: mironta Go to Quoted Post
Is it possible to run the Last preset at vMix startup?
Equivalent to selecting the Last button.
Thanks.
Just click on the last.vmix preset instead of opening vMix first
thanks 2 users thanked doggy for this useful post.
mironta on 10/18/2022(UTC), elvis55 on 10/18/2022(UTC)
Joeboe
#2 Posted : Tuesday, October 18, 2022 3:32:13 AM(UTC)
Joeboe
Right click on the windows icon (bottom left on task bar), select Run, type : Shell:startup, a window will open,... now do a search vmix last, open file location, copy and past it in the shell startup folder....restart the PC, and you should have vmix launch last preset automatically after windows logon.....Think that is how I did it....or, send a shortcut to desktop, and launch vmix from there...
User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#3 Posted : Tuesday, October 18, 2022 11:31:54 PM(UTC)
Winops
Argentina
hi
create a shortcut of last.vmix
cut into the folder
shell:startup
for advanced login mehthods
that used to type username and password use autologin
could be found on microsoft technet gallery
