Run Last preset at startup?
Originally Posted by: mironta  Is it possible to run the Last preset at vMix startup? Equivalent to selecting the Last button. Thanks. Just click on the last.vmix preset instead of opening vMix first
 2 users thanked doggy for this useful post.
Right click on the windows icon (bottom left on task bar), select Run, type : Shell:startup, a window will open,... now do a search vmix last, open file location, copy and past it in the shell startup folder....restart the PC, and you should have vmix launch last preset automatically after windows logon.....Think that is how I did it....or, send a shortcut to desktop, and launch vmix from there...
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi create a shortcut of last.vmix cut into the folder shell:startup for advanced login mehthods that used to type username and password use autologin could be found on microsoft technet gallery
