3 Pages<123
raugert
#41 Posted : Monday, October 17, 2022 12:21:08 AM(UTC)
raugert
Canada
Hi burie,
It’s good that you can see the Input Names in the pulldown. That means you are connected OK to vMix. It sounds like you might be missing something in the command for controlling the title. If you add a simple « Cut » command, does it control vMix ok ? You can send me your file at info@studio793.ca if you like. I can have a look at it. Just use the export feature.
Richard
-TA_
#42 Posted : Monday, October 17, 2022 6:51:07 PM(UTC)
-TA_
Originally Posted by: burie Go to Quoted Post
Why does these tool not work with my vMix25 4k Version?
Please be more specific..
Does the application load ok ?
Are you running the application from the vMix computer or on an another computer on the same network ?
Can you see the input names from vMix in the Script Builder's "Input" dropdown ? If not, it's a network issue. Perhaps wrong IP and Port number ?
Does the application load ok ? - Seems ok
It is the vMix machine. The plan is usage with Tablet, but step by step...
Yes, I can See the Inputs and the field names
I am able to create multiple lines of commands, but if I click on "Test Script" nothing happens in my vmix titles
vMix -> settings -> Web controller -> untick "Enable echanced security on Web and TCP API"
-Tommi
nikolajvavilov
#43 Posted : Thursday, November 24, 2022 12:02:41 AM(UTC)
nikolajvavilov
Sweden
A super big thanks for the software and your updates <3
Guest (14)
3 Pages<123
