I just updated to vMix 24.0.0.72 and I'm getting a "Loading Preset" box that stays there for several minutes and then I get a "Your device ran into a problem window". I eventually get a message about mz0380.64.sys
I know this is an old post, but same here, vMix is stuck at Loading Preset forever.
Thing is : - Only one preset is doing this - This preset is opening as normal on my other PC - My other presets opening as normal on both PCs
Did you manage to find a way ?
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Might be an Input (e.g. Audio Input) that requires a driver not functioning (well) on the PC with the issue. Try opening the Preset and de-select Inputs that potentially might cause the issue.
Originally Posted by: richardgatarski  Might be an Input (e.g. Audio Input) that requires a driver not functioning (well) on the PC with the issue. Try opening the Preset and de-select Inputs that potentially might cause the issue. For my case, you were right. Even if not having any error message, inputs with a large video file was causing it. This may explain why a more powerful computer was able to open the preset. I compressed these video files and it's ok now.
