GT
Ticker Bug with Big Font Sizes
Joined: 4/2/2016(UTC) Posts: 41   Location: Austria Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
A client wants to have a Ticker with "BIG TALL LETTERS" scrolling as pre/post-show. It doesn't matter which ticker I use (GT Ticker included in vMix or newly made with the GT Title Designer) the Text gets cut off at some point. Here is a sample picture: I have the Alphabet scrolling and the R gets cut off somehow.  To recreate the bug, create a ticker, change the font size to 565, and have a longer text of around 24 letters. If you have "ABCDEFGHIJKLMNOPQRSTUVWXYZ" as the text the ticker will start cutting off letters after the letter V. I wasn't able to find a fix. Changing Box-Sizing, Type or Compositing Mode doesn't change anything. Only the font-size does. Thanks!
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Seems to be font/size related ( maybe the ticker has a max textlength in pixels)
With Arial i get to halfway V, others go further (same size)
Originally Posted by: doggy  Seems to be font/size related ( maybe the ticker has a max textlength in pixels) Yes, that's what I thought as well. Wondering if the textlength in pixels can be changed.
Originally Posted by: Streamverse.tv  Originally Posted by: doggy  Seems to be font/size related ( maybe the ticker has a max textlength in pixels) Yes, that's what I thought as well. Wondering if the textlength in pixels can be changed. reduce font size ;-)
Originally Posted by: doggy  Originally Posted by: Streamverse.tv  Originally Posted by: doggy  Seems to be font/size related ( maybe the ticker has a max textlength in pixels) Yes, that's what I thought as well. Wondering if the textlength in pixels can be changed. reduce font size ;-) not an option. As described client wants "BIG TALL LETTERS". And it is clearly a bug. Even with a smaller font size it cuts off eventually.
Originally Posted by: Streamverse.tv  Originally Posted by: doggy  Originally Posted by: Streamverse.tv  Originally Posted by: doggy  Seems to be font/size related ( maybe the ticker has a max textlength in pixels) Yes, that's what I thought as well. Wondering if the textlength in pixels can be changed. reduce font size ;-) not an option. As described client wants "BIG TALL LETTERS". And it is clearly a bug. Even with a smaller font size it cuts off eventually. Agree is sort of a bug (a job for vMix team to check out or eexplain as to why) On the other hand I personally would not want to try to read a ticker that size (Many words would not even be completely displayed as a whole) . Not everything a client wants is for the best, your job is to point that out
Maybe follow workaround helps: Use small fonts and use the zoom in position setting to expand the ticker in the size you need.
GT
