Streamverse.tv
#1 Posted : Thursday, October 13, 2022 12:00:59 AM(UTC)
Streamverse.tv
Austria
A client wants to have a Ticker with "BIG TALL LETTERS" scrolling as pre/post-show.
It doesn't matter which ticker I use (GT Ticker included in vMix or newly made with the GT Title Designer) the Text gets cut off at some point.
Here is a sample picture:
I have the Alphabet scrolling and the R gets cut off somehow.
Screenshot of problem
To recreate the bug, create a ticker, change the font size to 565, and have a longer text of around 24 letters. If you have "ABCDEFGHIJKLMNOPQRSTUVWXYZ" as the text the ticker will start cutting off letters after the letter V.
I wasn't able to find a fix. Changing Box-Sizing, Type or Compositing Mode doesn't change anything. Only the font-size does.
Thanks!
#2 Posted : Thursday, October 13, 2022 12:40:36 AM(UTC)
Seems to be font/size related ( maybe the ticker has a max textlength in pixels)
With Arial i get to halfway V, others go further (same size)
Streamverse.tv
#3 Posted : Thursday, October 13, 2022 12:47:05 AM(UTC)
Streamverse.tv
Austria
Yes, that's what I thought as well. Wondering if the textlength in pixels can be changed.
#4 Posted : Thursday, October 13, 2022 1:15:44 AM(UTC)
reduce font size ;-)
Streamverse.tv
#5 Posted : Thursday, October 13, 2022 5:48:03 PM(UTC)
Streamverse.tv
Austria
not an option. As described client wants "BIG TALL LETTERS". And it is clearly a bug. Even with a smaller font size it cuts off eventually.
#6 Posted : Thursday, October 13, 2022 7:29:56 PM(UTC)
Agree is sort of a bug (a job for vMix team to check out or eexplain as to why)
On the other hand I personally would not want to try to read a ticker that size (Many words would not even be completely displayed as a whole) . Not everything a client wants is for the best, your job is to point that out
quinte
#7 Posted : Wednesday, November 2, 2022 9:26:20 AM(UTC)
quinte
Maybe follow workaround helps:
Use small fonts and use the zoom in position setting to expand the ticker in the size you need.
