Control vMix with Ross Talk
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Does anyone know if you can use RossTalk to control vMix from a Carbonite switcher? Just wanting to use vMix for graphics playout and was wondering if it is possible?
Joined: 8/1/2023(UTC) Posts: 1  Location: Los Angeles
Hello! Came here to say I would also like to know about this workflow.
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
You'll need something in the middle to translate, vMix won't directly respond to RossTalk or anything the Ross will send out. Tally outputs are a good way to start though.
Joined: 7/6/2021(UTC) Posts: 23   Location: Münster Thanks: 4 times
I created a new device at the Ross Dasboard under "Configuration" - "Devices" with "Type RossTalk", "Driver generic_1.0", "Port 8099", "IP Adress (IP of vMix)"
So I can create a custom control with "Command Category: Devices" "Devices: RossTalk (Generic)" "RossTalk (Generic): RossTalk Custom Cmd(CRLF)"
"RossTalk Device generic_1.0-S8" "Custom Cmd: FUNCTION Play Input=Abspann.mp4"
And now I can start the Abspann from the Carbonite console
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Originally Posted by: AudioGreg  You'll need something in the middle to translate, vMix won't directly respond to RossTalk or anything the Ross will send out.. maybe this will help: Bitfocus Companion
