mateogallegotv
#1 Posted : Wednesday, September 14, 2022 6:23:19 PM(UTC)
mateogallegotv
Spain
Hi guys,
I need to read into a variable a Dynamic Value but I don't know where to start.
I have three shortcuts which sets different Dynamic Values. (35, 40 and 45).
My script is supposed to read those numbers and do some stuff depending which number is set up.
Thanks in advance.
Mateo
#2 Posted : Wednesday, September 14, 2022 7:30:34 PM(UTC)
Originally Posted by: mateogallegotv Go to Quoted Post
Hi guys,
Thanks in advance.
Mateo
DynamicInputs and DynamicValues are intended to make functions used in scripts dynamic , not as a general variable storage space
That said you can use them as such by reading their content through the API XML within a script just like any other item from that xml
or if one does not want to deal with xpaths for reading said xml one can use a title as intermediate holdingplace
Code:
API.Function("SetDynamicValue1",Value:="40" )
' --By reading the API XML ---------------------------------------
dim xml as string = API.XML()
   x.loadxml(xml)
dim demo as string  = (x.SelectSingleNode("//dynamic/value1").InnerText)
console.writeLine("demo : " & demo)
' --OR if one does not want to deal with reading API XML (intended use of DynamicInputs and values)----------
API.Function("SetDynamicInput1",Value:="Title.gtzip" )
API.Function("SetDynamicValue1",Value:="35" )
API.Function("SetText",Input:="Dynamic1",SelectedName:="Headline.Text",Value:="Dynamic1" )
'OR
Input.Find("Dynamic1").Text("Headline.Text")= "Dynamic1"
dim test as string = Input.Find("Title.gtzip").Text("Headline.Text")
console.writeLine("demo : " & test)
Check out "Scripting for dummies" post in this forum
mateogallegotv
#3 Posted : Wednesday, September 14, 2022 7:38:56 PM(UTC)
mateogallegotv
Spain
Hi guys,
Thanks in advance.
Mateo
Code:
   x.loadxml(xml)
'OR
Thanks!!
Using a Title as placeholder could work.
