3rd Party Software and Development
Vmix Scripting | How can I get into a variable a DynamicValue
Hi guys,
I need to read into a variable a Dynamic Value but I don't know where to start.
I have three shortcuts which sets different Dynamic Values. (35, 40 and 45).
My script is supposed to read those numbers and do some stuff depending which number is set up.
Thanks in advance.
Mateo
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks in advance.
Mateo DynamicInputs and DynamicValues are intended to make functions used in scripts dynamic , not as a general variable storage space That said you can use them as such by reading their content through the API XML within a script just like any other item from that xml or if one does not want to deal with xpaths for reading said xml one can use a title as intermediate holdingplace Code:
API.Function("SetDynamicValue1",Value:="40" )
' --By reading the API XML ---------------------------------------
dim xml as string = API.XML()
x.loadxml(xml)
dim demo as string = (x.SelectSingleNode("//dynamic/value1").InnerText)
console.writeLine("demo : " & demo)
' --OR if one does not want to deal with reading API XML (intended use of DynamicInputs and values)----------
API.Function("SetDynamicInput1",Value:="Title.gtzip" )
API.Function("SetDynamicValue1",Value:="35" )
API.Function("SetText",Input:="Dynamic1",SelectedName:="Headline.Text",Value:="Dynamic1" )
'OR
Input.Find("Dynamic1").Text("Headline.Text")= "Dynamic1"
dim test as string = Input.Find("Title.gtzip").Text("Headline.Text")
console.writeLine("demo : " & test)
Check out "Scripting for dummies" post in this forum
Thanks in advance.
x.loadxml(xml)
'OR
Check out "Scripting for dummies" post in this forum Thanks!! Using a Title as placeholder could work.
