28 Pages«<1213141516>»
#261 Posted : Sunday, June 12, 2022 4:52:57 PM(UTC)
Originally Posted by: kolorasta Go to Quoted Post
Hi. How can I change the source of an Image Input... ?
For example, I have an input with the image somefile.png and I want to change it to somefile2.png via api
Which function should I use? i can't find it.
sorry for my english
You can not because there is none (https://forums.vmix.com/posts/t5032-Is-there-anyway-to--Change--an-input-in-the-API)
Can however if it is in a title (hint, latest v25)
Or choose a photo input
Nguyendung
#262 Posted : Sunday, August 14, 2022 12:15:58 PM(UTC)
Nguyendung
Viet Nam
Hello, first of all, sorry for my English. I hope you can understand me.
I write for the following:
If AudioBus (input1) on D,E bus and AudioBus (input2) on D bus then "Do nothing"
Else
AudioBus (input1) on D bus and AudioBus (input2) on C bus
I dont know what to do.
Please help me! Thanks a lot.
Roy Sinclair
#263 Posted : Monday, August 15, 2022 8:35:42 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Else
This code from the original post in this thread shows how to query the state of vMix and select specific items from the XML that vMix returns.
Code:
'Is a input Running or on Pause retrieved from the API xml
dim xml = API.XML()
x.loadxml(xml)
dim StateOf = (x.SelectSingleNode("//input[@type='Replay']/@state").Value)
'or
dim StateOf = (x.SelectSingleNode("//input[@number='10']/@state").Value)
Console.WriteLine(StateOf)
As long as vMix includes which audio busses any specific input has active then what you ask should be possible. I cannot say what is provided as I don't have an example of a vMix status handy but examining one is where I would start. Check any information that is returned about a speficic input AND check for any other XML referring to Audio busses, what you are looking for could be in either, both or none. If none then it's not going to be possible without a feature request to include more information in the state XML.
thanks 1 user thanked Roy Sinclair for this useful post.
Nguyendung on 1/5/2024(UTC)
Wayne Herbert
#264 Posted : Tuesday, August 30, 2022 12:46:28 AM(UTC)
Wayne Herbert
South Africa
Good Day i am Bad at Scripting to start
Is there a way of making GT Titles Toggle the Visible not Visible Via a Data source for like 90 or so items
JACKPOT 1.png (1,237kb) downloaded 13 time(s).
I Have Red Tiles with Numbers in them now what i want to happen is if there is a number in the tile i want the tile to be Visible when there is no number i want tile not to be there
i did this with data source how ever the tile does not return when data is re added
WTW TEST - BET TYPES - .xlsx (34kb) downloaded 11 time(s).
I need some help
Chris Daum
#265 Posted : Sunday, September 11, 2022 10:19:05 AM(UTC)
Chris Daum
Germany
Cheers Wayne,
just did a little testing, here´s is what I got:
Code:
Dim TbxContent As String
Dim Tbx As String
Dim Img As String
Do
For i As Integer = 1 To 4
Tbx = ("txt" & i & ".Text")
Img = ("Img" & i & ".Source")
TbxContent = Input.Find("Test").Text(Tbx)
If String.IsNullOrEmpty(TbxContent) Then
api.function("SetImageVisibleOff", input:="Test", SelectedName:=Img)
Else
api.function("SetImageVisibleOn", input:="Test", SelectedName:=Img)
End If
Next
Loop
Note:
Tbx in the above script represents the textfield name in my test title
Img the image name
Test is the name of my title input
In my test title both correspond to each other, means:
tbx1.Text is placed on img1.Source (these are the original names in my title)
Code:
<text index="0" name="txt4.Text">s</text>
<text index="1" name="txt3.Text">aa</text>
<text index="2" name="txt2.Text">aa</text>
<text index="3" name="txt1.Text">ss</text>
<image index="0" name="Img4.Source">45ac9978-9d83-4fa1-a514-086055a3618d\Bild1.png</image>
<image index="1" name="Img3.Source">45ac9978-9d83-4fa1-a514-086055a3618d\Bild1.png</image>
<image index="2" name="Img2.Source">45ac9978-9d83-4fa1-a514-086055a3618d\Bild1.png</image>
<image index="3" name="Img1.Source">45ac9978-9d83-4fa1-a514-086055a3618d\Bild1.png</image>
I have no idea how to access the image related to the textfield if naming in your .gtzip isn´t
built like that!
´nother note you can only set images on/off if you used "Rectangles" I have no idea how to
change their properties via script...
and... my for loop only counts to 4 I had it loop for testing purpose counting to 100 all good, vMix doesn´t seem to care if gets delivered empty strings... :-)
the script of course has to run in a loop during your show, but that should´t much of an issue...
for testing purpose I removed the text in the title editor (manually) the corresponding image went on and off
have fun
If you have further issues down there, let me know I know how to get on a plane :-) :-)
engelschall
#266 Posted : Sunday, September 11, 2022 5:57:28 PM(UTC)
engelschall
Germany
Was thanked: 33 time(s) in 17 post(s)
In case you are searching for real-life and working examples of more elaborate and clean vMix VB.Net scripts, check out https://github.com/rse/vmix-scripts/. Here you can find many reusable code snippets you can borrow.
titasas
#267 Posted : Monday, September 12, 2022 8:15:40 PM(UTC)
titasas
Lithuania
Hello 🙂
Maybe anyone can help with scripting? Never done this but i need something very simple.
if home-powerplay.gtzip input pp.Text is more then 0:01, then function MultiViewOverlayOn to scoreboard input Value 1.
If home-powerplay.gtzip input pp.Text is empty, then function MultiViewOverlayOff to scoreboard input Value 1.
To put it simply, in ice hockey I need scoreboard input layer 1 to turn on when the penalty minutes start ticking, and when the pp.Text field is empty, scoreboard input layer 1 turns off.
Thanks!
#268 Posted : Monday, September 12, 2022 8:40:04 PM(UTC)
Originally Posted by: titasas Go to Quoted Post
Hello 🙂
Thanks!
There are quit a bit of examples in this post on how to read values from a title text field .
All you need is to compare those values with your criteria in a script (if-then-else in vb.net speak) and activate the functions accordingly your matching criteria
If...Then...Else Statement
titasas
#269 Posted : Monday, September 12, 2022 8:59:13 PM(UTC)
titasas
Lithuania
Hello 🙂
Thanks!
maybe something worked out
do while True
if Input.Find("home-powerplay.gtzip").Text("pp.Text") >= "0:01" then
API.Function("MultiViewOverlayOn", Input:="scoreboard.gtzip", Value:="1")
else
API.Function("MultiViewOverlayoff", Input:="scoreboard.gtzip", Value:="1")
end if
sleep(500)
Loop
#270 Posted : Monday, September 12, 2022 9:31:43 PM(UTC)
Code:
do while True
 else
 end if
sleep(500)
Loop
take note theat the new name for the "MultiViewOverlay" is now simply "Layer"
keep in mind that a script and the functions do need more than 0.01 secs to process .
your sleep is half a second !
clibil
#271 Posted : Tuesday, September 13, 2022 4:45:35 PM(UTC)
clibil
Rank:: Member
Hi
I am a newbie to scripting but not to VMix.
Is there a way to select a Camera in a Virtual Studio Input ?
As part of a script I need to be able to make the input choose a specific camera position.
Does anyone know if there is a function which enables this please ?
Many thanks
#272 Posted : Tuesday, September 13, 2022 5:15:19 PM(UTC)
Originally Posted by: clibil Go to Quoted Post
Hi
Many thanks
isnt a virtual studio from a camera position on its own so select another VS (input) ?
clibil
#273 Posted : Tuesday, September 13, 2022 7:19:17 PM(UTC)
clibil
Rank:: Member
Good morning Doggy
First of all thank you for responding so quickly 🙂
A VMix-supplied virtual studio set appears as a single Input, and then there are (on the one I am using at least) 4 camera positions provided. They are, in effect, pre-set Zoom Levels. Unfortunately there seems to be no way to access these via a function command.
Clibil
#274 Posted : Tuesday, September 13, 2022 7:25:07 PM(UTC)
Good morning Doggy
Clibil
Oh talking about various zoom positions in your VS
Google could have told you ;-)
https://www.vmix.com/knowledgebase/article.aspx/204/how-to-change-virtual-set-zoom-positions-angles-using-shortcuts
if a shortcut exists a function for scripting does too ;-)
clibil on 9/13/2022(UTC)
clibil
#275 Posted : Tuesday, September 13, 2022 7:39:08 PM(UTC)
clibil
Rank:: Member
Thank you so very much - without your help I would have never tracked this down !
titasas
#276 Posted : Thursday, September 15, 2022 5:34:33 AM(UTC)
titasas
Lithuania
Code:
do while True
 else
 end if
sleep(500)
Loop
Now I'm thinking how to upgrade this code and also add them to change position.
If input1 is more than 0:01, enable it. If at that time input2 is more than 0:01, turn it on as well.
If input1 becomes empty, and input2 is still timed out, switch input1 off, move input2 to input1 position. At the end of the time, return to the previous position. If neither input gets time, both layers are disabled.
#277 Posted : Thursday, September 15, 2022 5:45:59 AM(UTC)
Code:
do while True
 else
 end if
sleep(500)
Loop
Just translate your thought/logic into code (language), you know: if then else/elseif's and's and or's etc
or are you trying to trick someone into doing that for you ;-)
titasas
#278 Posted : Thursday, September 15, 2022 6:12:24 AM(UTC)
titasas
Lithuania
Code:
do while True
 else
 end if
sleep(500)
Loop
I tried to create that, but for me is too much "if" and "or", but you remember me that is "elseif". Just cant find function to move X layer position :?
#279 Posted : Thursday, September 15, 2022 6:20:46 AM(UTC)
Code:
do while True
 else
 end if
sleep(500)
Loop
Can always use the setzoom, setpanx, setpanY to the input used in the layers instead
titasas
#280 Posted : Thursday, September 15, 2022 6:34:30 AM(UTC)
titasas
Lithuania
Code:
do while True
 else
 end if
sleep(500)
Loop
Thanks, but elseif not work for me :|
Code:
[i]do while True
 if Input.Find("home-powerplay2.gtzip").Text("pp.Text") >= "0:01" then
   API.Function("MultiViewOverlayOn", Input:="scoreboard.gtzip", Value:="5")
 elseif
    Input.Find("home-powerplay.gtzip").Text("pp.Text") >= "0:01" and Input.Find("home-powerplay2.gtzip").Text("pp.Text") >= "0:01" then
 elseif
    Input.Find("home-powerplay.gtzip").Text("pp.Text") < "0:01" and Input.Find("home-powerplay2.gtzip").Text("pp.Text") >= "0:01" then
   API.Function("MultiViewOverlayOff", Input:="scoreboard.gtzip", Value:="1")
   API.Function("MultiViewOverlayOn", Input:="scoreboard.gtzip", Value:="5") and something with setpanX
 else
   API.Function("MultiViewOverlayOff", Input:="scoreboard.gtzip", Value:="5")
 end if
sleep(500)
Loop[/i]
And get Error Line 4 BC30201: Expression expected error
Guest (9)
