Audio playing cannot turn it off
This is strange. So I have 2 HDMI capture cards that are the same make/model called MiraBox. As you can see in t  Audio Off.png (113kb) downloaded 1 time(s).he picture, the one on the left is showing some audio coming in but the one on the right does not, BUT the one on the right is playing the sound on my PC even though the Audio button is not green. Now when I am streaming, people hear the audio fine, even though there is no indication that it is receiving  Audio Off.png (113kb) downloaded 1 time(s). Audio Off.png (113kb) downloaded 1 time(s). audio, and I have to listen to the audio the entire time the input is "off". to be clear, the viewers cannot hear the audio when the "audio" button is not green, but they hear it fine when the "Audio" button is green. I just can't make the audio stop when the "Audio" button is turned off, it is super annoying. in the attached picture, this is exactly how it is right now while typing this, and I hear everything on my speakers. Since there is no "mute in headphones" option, I am not sure how to fix this issue. Thoughts? Thanks in advance. Loving this software by the way...the integration to Google Sheets is impressive...you can catch how we used it last night here: - we used Google Sheets to keep our times, and setup vMix (using title designer) and it works like a charm. THANK YOU !!! Windows 11 Pro version 10.0.22000 Build 22000
Joined: 6/5/2020(UTC) Posts: 55  Location: California Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
There could be a few things going on here, though not enough info here to troubleshoot.
for the issue of not seeing meters, you should make sure that the "visible in mixer" box is checked in the input audio options. (do you see it as a source in your mixer audio input list?)
as for the PC constantly playing the audio, can be two things, you have the solo button selected on the input, or your PC is configured to take the audio in on that capture card and play it to PC speakers (this would be outside of vMix)
 1 user thanked Paul Camino for this useful post.
Thanks Paul! The visible in mixer was it! I didn't catch that. The other audio issue i will work on when back to the machine later today. thank you!
Did you get the second part of this solved?
Well, I only had to do this for the one day. My normal broadcasting doesn't require this. I will try and test it out another day.
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: presidiodog  Well, I only had to do this for the one day. My normal broadcasting doesn't require this. I will try and test it out another day. Check which Audio Buses are enabled for each of those Inputs and which audio buses are fed to your stream.
