Joined: 8/25/2022(UTC) Posts: 8  Location: hasharon Thanks: 2 times
hey i try the vmix 25 i want to buy and recoored and streming when i try to recored i get this error  error .jpg (140kb) downloaded 7 time(s). i try a lot of things to change but Without success why this happend in the settings i see that the recording is invalid format  recording settings.jpg (60kb) downloaded 5 time(s).what can i do ??
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
{0} - {1:dd MMMM yyyy - hh-mm-ss tt} copy paste this to resolve the issue
Also check the name of the file and the destination, your file is being saved into a Onedrive folder
 1 user thanked DetoxX for this useful post.
Originally Posted by: DetoxX  {0} - {1:dd MMMM yyyy - hh-mm-ss tt} copy paste this to resolve the issue I try this but nothing happend it's the same error like in the picture Originally Posted by: DetoxX  Also check the name of the file and the destination, your file is being saved into a Onedrive folder I save it on d:\test But the onedrive backup the entire computer to the onedrive
Joined: 6/15/2021(UTC) Posts: 4  Location: Middlesex Was thanked: 1 time(s) in 1 post(s)
pretty sure your MM for the months should be only 2 and not 4
Thank you for your help I am change the month to mm But it's the same error
@ Yaniv134
What Calendar is Windows using? If not set to the Gregorian Calendar, then I suspect that might be the issue you are encountering.
Ice You are a genius, I changed the calendar template, restarted the computer and it worked, thank you very much Do you know if it is possible to record on a green screen background and at the same time broadcast on a non-green screen background?
Record green screen using the multicoder and the final mix output with the recorder, you also have other output options with NDI recording as well
