yaniv134
#1 Posted : Thursday, August 25, 2022 4:00:43 AM(UTC)
yaniv134
Israel
hey i try the vmix 25
i want to buy and recoored and streming
when i try to recored i get this error
error .jpg (140kb) downloaded 7 time(s).
i try a lot of things to change but Without success
why this happend
in the settings i see that the recording is invalid format
recording settings.jpg (60kb) downloaded 5 time(s).
what can i do ??
DetoxX
#2 Posted : Thursday, August 25, 2022 12:44:01 PM(UTC)
DetoxX
{0} - {1:dd MMMM yyyy - hh-mm-ss tt}
copy paste this to resolve the issue
Also check the name of the file and the destination, your file is being saved into a Onedrive folder
thanks 1 user thanked DetoxX for this useful post.
yaniv134 on 8/26/2022(UTC)
yaniv134
#3 Posted : Friday, August 26, 2022 2:33:34 AM(UTC)
yaniv134
Israel
I try this but nothing happend it's the same error like in the picture
I save it on d:\test
But the onedrive backup the entire computer to the onedrive
Javeer
#4 Posted : Friday, August 26, 2022 9:46:32 AM(UTC)
Javeer
pretty sure your MM for the months should be only 2 and not 4
yaniv134
#5 Posted : Friday, August 26, 2022 8:59:16 PM(UTC)
yaniv134
Israel
Thank you for your help
I am change the month to mm
But it's the same error
#6 Posted : Friday, August 26, 2022 9:42:00 PM(UTC)
@ Yaniv134
What Calendar is Windows using?
If not set to the Gregorian Calendar, then I suspect that might be the issue you are encountering.
yaniv134
#7 Posted : Sunday, August 28, 2022 5:16:30 AM(UTC)
yaniv134
Israel
Originally Posted by: IceStream Go to Quoted Post
@ Yaniv134
You are a genius, I changed the calendar template, restarted the computer and it worked, thank you very much
Do you know if it is possible to record on a green screen background and at the same time broadcast on a non-green screen background?
DetoxX
#8 Posted : Sunday, August 28, 2022 6:33:34 PM(UTC)
DetoxX
Record green screen using the multicoder and the final mix output with the recorder, you also have other output options with NDI recording as well
