GT
Position an object based on data source
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Is it possible to use a number in a Google Sheet to set the x position of a PNG sequence? My client wants the animated backplate to be positioned based on how long the text is for each lower third.
I can count the string length and figure out the right multiplier, but is it possible to use that number from the data source to position that object?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Geoff B  Is it possible to use a number in a Google Sheet to set the x position of a PNG sequence? My client wants the animated backplate to be positioned based on how long the text is for each lower third.
I can count the string length and figure out the right multiplier, but is it possible to use that number from the data source to position that object? Not within the (same) GT title One can position (pan) an input though with shortcut/function
Originally Posted by: doggy  Not within the (same) GT title One can position (pan) an input though with shortcut/function Hi Doggy, I appreciate your reply! I could just do the text part in GT Title and do the PNG sequence (backplate) in vMix. But I'm still trying to figure out how to get the number from the data source into the shortcut/function. I'm guessing a hidden cell in the title is part of the method. But how to read the data from the hidden cell and put it into the SetPanX function?
Originally Posted by: Geoff B  Originally Posted by: doggy  Not within the (same) GT title One can position (pan) an input though with shortcut/function Hi Doggy, I appreciate your reply! I could just do the text part in GT Title and do the PNG sequence (backplate) in vMix. But I'm still trying to figure out how to get the number from the data source into the shortcut/function. I'm guessing a hidden cell in the title is part of the method. But how to read the data from the hidden cell and put it into the SetPanX function? Check out the scripting for dummies post on how to read value from a title
I have tried to extract the method from the scripting for dummies thread, but I'm getting syntax errors. I obviously don't understand the VB.net part. Code:dim xPos as decimal
xPos = Input.Find("vmware l3.gtzip").Text("Length.Text")
Function=SetPanX&Value=xPos,Input="Backplate"
Function=Overlay4In&input="L4 Comp"
The first two lines return syntax errors.
Originally Posted by: Geoff B  I have tried to extract the method from the scripting for dummies thread, but I'm getting syntax errors. I obviously don't understand the VB.net part. Code:dim xPos as decimal
The first two lines return syntax errors. The Error give explains what is wrong ! Quote:Script 'Script1' Error Line 2: Conversion from string to type 'Decimal' is not valid. One can not put a string into a decimal ( and visa versa), one needs to convert that Or read it to a string and convert it to a decimal after ( or in the function code)
The Error give explains what is wrong ! Quote:Script 'Script1' Error Line 2: Conversion from string to type 'Decimal' is not valid. That's not the error I'm getting. This is the error I get: Error Line 1: Invalid Syntax: dim xPos as decimalIf I comment out line 1, I get another syntax error on line 2.
Looks fine though (line 1) and works fine to (you know i do test ;-) ) Try with another name for the variable
rest of my comment stands though ( errors not always point to the location of where the couse of the error is , only where it happens
Variable As String !!!! and convert to a decimal ( other variable if needed) for use in the function
Originally Posted by: doggy  Looks fine though (line 1) and works fine to (you know i do test ;-) ) Try with another name for the variable
Variable As String !!!! and convert to a decimal ( other variable if needed) for use in the function I appreciate your time! Seems like I can't dim anything. Am I missing a step that enables VB.net?
Originally Posted by: Geoff B  Originally Posted by: doggy  Looks fine though (line 1) and works fine to (you know i do test ;-) ) Try with another name for the variable
Variable As String !!!! and convert to a decimal ( other variable if needed) for use in the function I appreciate your time! Seems like I can't dim anything. Am I missing a step that enables VB.net? You are writing the script in the vMix Scripting right ? ( Settings -Scripting) You do save after edit right and then try to run ? make sure the right script is selected if you have more Check if you dont have multiple editing windows active And you are using vMix 4K or above ? There is no need to enable vb.net
Originally Posted by: doggy  You are writing the script in the vMix Scripting right ? ( Settings -Scripting) You do save after edit right and then try to run ? make sure the right script is selected if you have more Check if you dont have multiple editing windows active And you are using vMix 4K or above ? There is no need to enable vb.net • Yep, I'm pretty good at scripting, just not VB.net • I'm using vMix Pro • Just one editing window open • I can't even save the script to try to run it, I get the Syntax Error when I try to save. I had to comment out the first two lines in order to save. • I get a syntax error, no matter what the variable is called or how I try to define it (decimal, integer, string)
weird try create a new script or make sure there is nothig hidden within (complete clear )
Originally Posted by: doggy  weird try create a new script or make sure there is nothig hidden within (complete clear ) OK... if I just have the top two lines in there, it works fine. Seems like I need to convert the Function= lines into API.Function ? Trying to figure out the right syntax for those.
GT
