Geoff B
#1 Posted : Thursday, August 18, 2022 2:48:04 PM(UTC)
Geoff B
Is it possible to use a number in a Google Sheet to set the x position of a PNG sequence? My client wants the animated backplate to be positioned based on how long the text is for each lower third.
I can count the string length and figure out the right multiplier, but is it possible to use that number from the data source to position that object?
#2 Posted : Thursday, August 18, 2022 5:58:22 PM(UTC)
Not within the (same) GT title
One can position (pan) an input though with shortcut/function
Geoff B
#3 Posted : Thursday, August 18, 2022 11:41:00 PM(UTC)
Geoff B
Hi Doggy, I appreciate your reply!
I could just do the text part in GT Title and do the PNG sequence (backplate) in vMix. But I'm still trying to figure out how to get the number from the data source into the shortcut/function. I'm guessing a hidden cell in the title is part of the method. But how to read the data from the hidden cell and put it into the SetPanX function?
#4 Posted : Friday, August 19, 2022 12:55:24 AM(UTC)
Check out the scripting for dummies post on how to read value from a title
Geoff B
#5 Posted : Saturday, August 20, 2022 11:44:45 PM(UTC)
Geoff B
I have tried to extract the method from the scripting for dummies thread, but I'm getting syntax errors. I obviously don't understand the VB.net part.
Code:
dim xPos as decimal
xPos = Input.Find("vmware l3.gtzip").Text("Length.Text")
Function=SetPanX&Value=xPos,Input="Backplate"
Function=Overlay4In&input="L4 Comp"
The first two lines return syntax errors.
#6 Posted : Sunday, August 21, 2022 12:53:25 AM(UTC)
Code:
dim xPos as decimal
The Error give explains what is wrong !
Script 'Script1' Error Line 2: Conversion from string to type 'Decimal' is not valid.
One can not put a string into a decimal ( and visa versa), one needs to convert that
Or read it to a string and convert it to a decimal after ( or in the function code)
Geoff B
#7 Posted : Sunday, August 21, 2022 1:13:14 AM(UTC)
Geoff B
That's not the error I'm getting.
This is the error I get:
Error Line 1: Invalid Syntax: dim xPos as decimal
If I comment out line 1, I get another syntax error on line 2.
#8 Posted : Sunday, August 21, 2022 1:20:01 AM(UTC)
Looks fine though (line 1) and works fine to (you know i do test ;-) )
Try with another name for the variable
rest of my comment stands though ( errors not always point to the location of where the couse of the error is , only where it happens
Variable As String !!!! and convert to a decimal ( other variable if needed) for use in the function
Geoff B
#9 Posted : Sunday, August 21, 2022 1:22:46 AM(UTC)
Geoff B
I appreciate your time!
Seems like I can't dim anything. Am I missing a step that enables VB.net?
#10 Posted : Sunday, August 21, 2022 1:36:08 AM(UTC)
You are writing the script in the vMix Scripting right ? ( Settings -Scripting)
You do save after edit right and then try to run ? make sure the right script is selected if you have more
Check if you dont have multiple editing windows active
And you are using vMix 4K or above ?
There is no need to enable vb.net
Geoff B
#11 Posted : Sunday, August 21, 2022 1:46:04 AM(UTC)
Geoff B
• Yep, I'm pretty good at scripting, just not VB.net
• I'm using vMix Pro
• Just one editing window open
• I can't even save the script to try to run it, I get the Syntax Error when I try to save. I had to comment out the first two lines in order to save.
• I get a syntax error, no matter what the variable is called or how I try to define it (decimal, integer, string)
#12 Posted : Sunday, August 21, 2022 1:53:12 AM(UTC)
weird
try create a new script or make sure there is nothig hidden within (complete clear )
Geoff B
#13 Posted : Sunday, August 21, 2022 2:05:07 AM(UTC)
Geoff B
weird
OK... if I just have the top two lines in there, it works fine.
Seems like I need to convert the Function= lines into API.Function ?
Trying to figure out the right syntax for those.
