ChristoffBW
#1 Posted : Thursday, August 11, 2022 10:41:05 PM(UTC)
ChristoffBW
South Africa
Hi, I'm busy doing some automations via tcp into vmix. Got it working as intended but spotted an issue with setting text fields of a title input over tcp.
If the value contains an '&' it just ignores it and anything after it. Is there a different syntax I can use to put the value for a field in quotations or brackets or something?
paco3346
#2 Posted : Thursday, August 11, 2022 11:22:34 PM(UTC)
paco3346
You need to URL encode your ampersand.
Replace it with %24
thanks 1 user thanked paco3346 for this useful post.
ChristoffBW on 8/11/2022(UTC)
ChristoffBW
#3 Posted : Thursday, August 11, 2022 11:47:32 PM(UTC)
ChristoffBW
South Africa
Replace it with %24
Gotcha, missed that part in the docs somehow. It's %26 for the ampersand btw ;)
Thanks for the help.
