Joined: 8/11/2022(UTC) Posts: 7  Location: Cape Town Thanks: 1 times
Hi, I'm busy doing some automations via tcp into vmix. Got it working as intended but spotted an issue with setting text fields of a title input over tcp. If the value contains an '&' it just ignores it and anything after it. Is there a different syntax I can use to put the value for a field in quotations or brackets or something?
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
You need to URL encode your ampersand.
Replace it with %24
 1 user thanked paco3346 for this useful post.
Originally Posted by: paco3346  You need to URL encode your ampersand.
Replace it with %24 Gotcha, missed that part in the docs somehow. It's %26 for the ampersand btw ;) Thanks for the help.
