Luigi
#1 Posted : Thursday, August 11, 2022 6:37:45 AM(UTC)
Luigi
Italy
La mia idea è questa: siccome il 4k è grande 4 volte un full hd, volevo poter usare una camera in 4k così da ottenere 4 inquadrature con una singola camera e fare streaming in full hd, vmix se aggiundo una camera 4k ad un progetto full hd auto ridimensiona la telecamera 4k in full hd, mentre sarebbe interessante mantenere la telecamera delle dimensioni reali, cioè 4 volte un full hd.
My idea is this: since 4k is 4 times the size of a full hd, I wanted to be able to use a 4k camera so as to get 4 shots with a single camera and stream in full hd, vmix if I add a 4k camera to a full project hd auto resizes the 4k camera to full hd, while it would be interesting to keep the camera at its real size, ie 4 times a full hd.
#2 Posted : Thursday, August 11, 2022 9:30:24 PM(UTC)
@ Luigi
YES, this is a common practice for a lot of vMix users with vMix 4K and above.
Luigi
#3 Posted : Thursday, August 11, 2022 9:36:12 PM(UTC)
Luigi
Italy
HOW CAN I DO IT WITH VMIX
Luigi
#4 Posted : Thursday, August 11, 2022 9:37:34 PM(UTC)
Luigi
Italy
VMIX RESIZE THE INPUTS ACCORDING TO THE PROJECT
vmixgreg
#5 Posted : Friday, August 12, 2022 5:47:24 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 19 time(s) in 18 post(s)
Hi Luigi,
Yes, the "Output" will be that of your project, but vMix retains the resolution of the source Input so when you zoom in up to 75% of a 4K source, the Output will still be full HD and should not pixelate.
You can check the resolution of any Input in its Settings:
cog wheel of Input ==> General tab ==> Resolution box along right side
vMix Greg
Luigi
#6 Posted : Friday, August 12, 2022 6:42:46 AM(UTC)
Luigi
Italy
THANK YOU FOR DEDICATING YOUR TIME TO ME
