User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#1 Posted : Tuesday, August 9, 2022 2:56:52 PM(UTC)
Winops
Argentina
I'm looking to bind an image to the end of any text segment in vmix titles
i also started vmix web API & can set text or image or visibility
but not such a function i found there ,
what is hard here ?
its positioning the specified image at the end of text segment dynamically in the playing ticker
simply i need something like this
[mytext2] [mylogo1] [mytext2] [mylogo2]
tnx alot
#2 Posted : Tuesday, August 9, 2022 5:25:08 PM(UTC)
what is hard here ?
What function are you looking for ?
In a title one can have text blocks and image placeholders. they are separate items meaning they are either a text or a an image and can not be switched from one to the other.
Ticker is text only !
one can use a font that has icons/emojis within (or create a font with own created icons)
#3 Posted : Wednesday, August 10, 2022 3:56:44 PM(UTC)
Winops
Argentina
First Tnx for Your Answer
then i saw this yesterday
it was amazing !
but just a little problem i have
is to be RTL not LTR
and edvin has no option built on there for direction .
any help for this ?
#4 Posted : Wednesday, August 10, 2022 5:03:26 PM(UTC)
it was amazing !
any help for this ?
LOL: reply to a comments below the vid "if you get an error, don't use it, .............."
as in it doesn't work in latest vMix 25 (does in 24)
#5 Posted : Saturday, August 13, 2022 2:18:05 PM(UTC)
Winops
Argentina
it was amazing !
any help for this ?
I know
but i need a technical reason to my Boss :-/ , for that creating RTL ticker images not possible in vmix !
tnx alot bro
Papo
#6 Posted : Sunday, August 14, 2022 1:04:29 AM(UTC)
Papo
Peru
changing the address of a ticker in xaml, particularly the one that vmix brings, is very easy, the point is to insert the images and not in a fixed position but in an indeterminate way, as I say changing the vmix xaml ticker is easy but it would only be text , but if you are Argentine so you would want an inverted ticker, only some eastern countries use that type of writing, or perhaps you would like to sell it since that tool is free, Excuse me for saying this but it seems that you are desperate with that option Since you post multiple comments about this, what specifically do you want it for?
translated from spanish to english by google
#7 Posted : Sunday, August 14, 2022 3:16:46 AM(UTC)
Again: Ticker is basically text only ( but that includes special characters/ emojies which one can easley create)
GT title lets you also easily change the direction of the ticker ( 4 directions) AND put the text in RTL!
Using data source format in the title setup you can add (special)charactors that will combine repeatedly with the data given
Like Papo said "what specifically do you want it for?" and how specifically would it have to look like before there is a complaint about some limitation inherent to any potential solution
And what's up with the webapi for this ?
#8 Posted : Sunday, August 14, 2022 3:06:43 PM(UTC)
Winops
Argentina
translated from Spanish to English by google
Hi
no not for sale
in the youtube sample i saw a useful wpf plug-in but it used animated ticker and not able to change direction to RTL !
that's All
1- RTL
2- Contains Images + Text
3- Bind Image to End of Each Text Part
4- WebApi Manageable (recommended)
tnx for ur help
#9 Posted : Sunday, August 14, 2022 3:21:21 PM(UTC)
Winops
Argentina
Hi
no not for sale
that's All
1- RTL
tnx for ur help
Back to top
#10 Posted : Sunday, August 14, 2022 3:36:21 PM(UTC)
Winops
Argentina
do you mean edit a gtzip content ?
and wich part should be?
#11 Posted : Sunday, August 14, 2022 6:46:27 PM(UTC)
NO ! ou dont want to mess with that if you dont even know how in general titles (GT) work
GT ticker one can change the direction either within the title designer or in the title editor (Ticker settings - clock icon)
If one uses a data source to populate the ticker one can edit the format of the data displayed ( standard it will be "{0}" but one can add text/icon/special characters like "{0} i added this icon " )
You have been given some options before but because you post all over the place (highjacking not related posts) and other media is hard to keep track of all the info allready given
one allready given was https://hologfx.io/ ( with icons)
Maybe do a google search on "html tickers with images" to get code examples
If one actualle creates one in GT with actual images the textfields will always be fixed size regardless of text length! https://payhip.com/vMixTidBits
BTW (WebApi Manageable (recommended)) what exactly needs to be managed ?
#12 Posted : Sunday, August 14, 2022 9:40:25 PM(UTC)
Winops
Argentina
the result was current date and time !
sure tnx
sure
tnx alot dude
"BTW (WebApi Manageable (recommended)) what exactly needs to be managed ?
i means to create such an vb.net app to manage over web api like this dual scheduler i wrote in vb.net win form .
and a second question
is there any way to program directly from vb.net into the vmix? not web api ?
#13 Posted : Sunday, August 14, 2022 11:25:38 PM(UTC)
Can you please use quotes and comments in your post corrently. its a mess to read and now everything is even more confusing as you are going all over the place in regards to what you want to do.
Please learn how to use data in a GT title ! The {0} reference is to be used with datasources , Not as part of a regular text content !!!
Guest (4)
