place same image between text segments in thicker using webapi
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
I'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such a function i found there , what is hard here ? its positioning the specified image at the end of text segment dynamically in the playing ticker simply i need something like this [mytext2] [mylogo1] [mytext2] [mylogo2] tnx alot
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Quote: I'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such a function i found there , what is hard here ? What function are you looking for ? In a title one can have text blocks and image placeholders. they are separate items meaning they are either a text or a an image and can not be switched from one to the other. Quote:its positioning the specified image at the end of text segment dynamically in the playing ticker simply i need something like this [mytext2] [mylogo1] [mytext2] [mylogo2] Ticker is text only ! one can use a font that has icons/emojis within (or create a font with own created icons)
Hi, First Tnx for Your Answer then i saw this yesterday it was amazing ! but just a little problem i have is to be RTL not LTR and edvin has no option built on there for direction . any help for this ?
Originally Posted by: Winops  Hi, First Tnx for Your Answer then i saw this yesterday it was amazing ! but just a little problem i have is to be RTL not LTR and edvin has no option built on there for direction . any help for this ? LOL: reply to a comments below the vid "if you get an error, don't use it, .............." as in it doesn't work in latest vMix 25 (does in 24)
Originally Posted by: doggy  Originally Posted by: Winops  Hi, First Tnx for Your Answer then i saw this yesterday it was amazing ! but just a little problem i have is to be RTL not LTR and edvin has no option built on there for direction . any help for this ? LOL: reply to a comments below the vid "if you get an error, don't use it, .............." as in it doesn't work in latest vMix 25 (does in 24) I know but i need a technical reason to my Boss :-/ , for that creating RTL ticker images not possible in vmix ! tnx alot bro
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
changing the address of a ticker in xaml, particularly the one that vmix brings, is very easy, the point is to insert the images and not in a fixed position but in an indeterminate way, as I say changing the vmix xaml ticker is easy but it would only be text , but if you are Argentine so you would want an inverted ticker, only some eastern countries use that type of writing, or perhaps you would like to sell it since that tool is free, Excuse me for saying this but it seems that you are desperate with that option Since you post multiple comments about this, what specifically do you want it for?
translated from spanish to english by google
Again: Ticker is basically text only ( but that includes special characters/ emojies which one can easley create) GT title lets you also easily change the direction of the ticker ( 4 directions) AND put the text in RTL! Using data source format in the title setup you can add (special)charactors that will combine repeatedly with the data given
Like Papo said "what specifically do you want it for?" and how specifically would it have to look like before there is a complaint about some limitation inherent to any potential solution And what's up with the webapi for this ?
Originally Posted by: Papo  changing the address of a ticker in xaml, particularly the one that vmix brings, is very easy, the point is to insert the images and not in a fixed position but in an indeterminate way, as I say changing the vmix xaml ticker is easy but it would only be text , but if you are Argentine so you would want an inverted ticker, only some eastern countries use that type of writing, or perhaps you would like to sell it since that tool is free, Excuse me for saying this but it seems that you are desperate with that option Since you post multiple comments about this, what specifically do you want it for?
translated from Spanish to English by google Hi no not for sale in the youtube sample i saw a useful wpf plug-in but it used animated ticker and not able to change direction to RTL ! that's All 1- RTL 2- Contains Images + Text 3- Bind Image to End of Each Text Part 4- WebApi Manageable (recommended) tnx for ur help
Originally Posted by: doggy  Again: Ticker is basically text only ( but that includes special characters/ emojies which one can easley create) GT title lets you also easily change the direction of the ticker ( 4 directions) AND put the text in RTL! Using data source format in the title setup you can add (special)charactors that will combine repeatedly with the data given
Like Papo said "what specifically do you want it for?" and how specifically would it have to look like before there is a complaint about some limitation inherent to any potential solution And what's up with the webapi for this ? Hi no not for sale in the youtube sample i saw a useful wpf plug-in but it used animated ticker and not able to change direction to RTL ! that's All 1- RTL 2- Contains Images + Text 3- Bind Image to End of Each Text Part 4- WebApi Manageable (recommended) tnx for ur help Back to top
do you mean edit a gtzip content ?  gtzip.png (44kb) downloaded 11 time(s).and wich part should be?
NO ! ou dont want to mess with that if you dont even know how in general titles (GT) work GT ticker one can change the direction either within the title designer or in the title editor (Ticker settings - clock icon) If one uses a data source to populate the ticker one can edit the format of the data displayed ( standard it will be "{0}" but one can add text/icon/special characters like "{0} i added this icon " ) You have been given some options before but because you post all over the place (highjacking not related posts) and other media is hard to keep track of all the info allready given one allready given was https://hologfx.io/ ( with icons) Maybe do a google search on "html tickers with images" to get code examples If one actualle creates one in GT with actual images the textfields will always be fixed size regardless of text length! https://payhip.com/vMixTidBitsBTW (WebApi Manageable (recommended)) what exactly needs to be managed ?
NO ! ou dont want to mess with that if you dont even know how in general titles (GT) work GT ticker one can change the direction either within the title designer or in the title editor (Ticker settings - clock icon) If one uses a data source to populate the ticker one can edit the format of the data displayed ( standard it will be "{0}" but one can add text/icon/special characters like "{0} i added this icon " ) the result was current date and time ! ticker2.PNG (59kb) downloaded 10 time(s).You have been given some options before but because you post all over the place (highjacking not related posts) and other media is hard to keep track of all the info allready given one allready given was https://hologfx.io/ ( with icons) Maybe do a google search on "html tickers with images" to get code examples sure tnxIf one actualle creates one in GT with actual images the textfields will always be fixed size regardless of text length! https://payhip.com/vMixTidBitssure tnx alot dude "BTW (WebApi Manageable (recommended)) what exactly needs to be managed ? " i means to create such an vb.net app to manage over web api like this dual scheduler i wrote in vb.net win form .  sch.PNG (77kb) downloaded 8 time(s).and a second question is there any way to program directly from vb.net into the vmix? not web api ?
Can you please use quotes and comments in your post corrently. its a mess to read and now everything is even more confusing as you are going all over the place in regards to what you want to do.
Please learn how to use data in a GT title ! The {0} reference is to be used with datasources , Not as part of a regular text content !!!
