Canvas with 2 camera inputs seperated by diagonal line
Hi All, The designer for an upcoming event designed a canvas where 2 player cameras should be in the scene next to each other with a diagonal line in between. I have created a Luma key file for each camera and created a virtual input from each camera and applied the luma key onto the camera. Luma Key:  What I now notice is that I am unable to move the camera left to get my player central in the cutout. I tried to create an extra virtual input where I first move the left player 50% left and the right player 50% right and I created a new virtual input from those moved feeds applying the luma key to that but that ends up giving the same result as creating my initial virtual input + move the base canvas + apply luma key and is not what I want. I want the luma key image linked above with in the white piece one player centered and in the black piece another player centered.     is there any way I can easily do this?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Use virtual set with UV maps or Use Mix input and mask that one
in both cases one can position the "person" to fit ,reposition the mask and easier to switch sources
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
For cases like this I make the mask be 3/4 +1/4 wide so that after I slide cam 1 left it ends up looking like a 1/2 + 1/2
Originally Posted by: paco3346  For cases like this I make the mask be 3/4 +1/4 wide so that after I slide cam 1 left it ends up looking like a 1/2 + 1/2 Thanks after making this post I also played around with this and that worked indeed. Thanks for the advice. I would still like to learn more on virtual sets and uv maps, any good guide anywhere ? Mix input also looks interesting for some other items I might encounter.
