adambou
#1 Posted : Sunday, August 7, 2022 9:17:26 PM(UTC)
adambou
was wondering if there is a way to play some replays full screen - which is my default - and then replays to play in picture in picture while the live camera continues.
I have my overlay4 set to p in p - so is there a way to trigger the last replay event to play on overlay4?
I can set the stinger to play in p in p but then the replay goes to full screen..
Thanks in advance.
Radiotvpat1982
#2 Posted : Monday, August 8, 2022 1:53:36 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
Yes, I do this in my sports production using the Merge feature.
I have created a script (triggered by a shortcut). That script applies a double box input. In one box is the camera, in the other box is the replay.
I have text one the boxes that say "Live" and "Replay". I Merge in to the box and out.
The script does the following:
Put the box in preview
Pauses a few frames (MIX calls is sleep)
Uses the Merge effect
Plays the replay with the "play selected" command
BTW, I never use the stinger feature. I instead just use my overlays just remember you get 4 my overlays go like this
1: Scorebug
2: Graphics
3: Watermarks
4: Overlays
Sometimes I bake in a watermark by creating a layer in each one of my shots. I do this whenever I use a telestrator on Overlay 3.
adambou
#3 Posted : Wednesday, August 17, 2022 11:13:38 PM(UTC)
adambou
So I went and learnt how to write scripts and I have basically done it. You advise and guidance is very much appreciated.
After playing the last event to the replay box, how do I merge back out to live?
Everything else is working fine. Is there a wait for completion of replay before merging back out option?
dmwkr
#4 Posted : Friday, August 19, 2022 11:01:34 PM(UTC)
dmwkr
Maybe post your script here.
Are you using the function "ReplayPlayLastEventToOutput"? With this function, it should transition back to preview.
