nidarosvideo
#1 Posted : Tuesday, August 2, 2022 12:36:04 AM(UTC)
nidarosvideo
Norway
How to set what inputs are selected by default?
We are doing a 4 camera sports event. When we create a new highlight the default selection is whatever was done on the previous highlight. This is not a good solution. We would like to have all 4 of them selected by default. I'm sure others have good reasons to want different default seletions.
How do we do this?
Radiotvpat1982
#2 Posted : Monday, August 8, 2022 1:59:12 AM(UTC)
Radiotvpat1982
Was thanked: 14 time(s) in 10 post(s)
Simple answer is no.
I get what you are saying though like maybe an option that said I always want input 2 marked by default.
Maybe that would make for a good feature request. You are correct though by default it is always what was checked last. VMIX replay does require you have something checked for each play, so I guess this was a logical way to do this. I run a lot of 3 Play and this is one difference between the two softwares.
If you really wanted to get advanced you could create a script that checked multiple inputs each time. If you dont know scripting well I recommend the free VMIX scripting app.
That and a couple Youtube how to videos would have you set for this pretty easily.
