Shortcuts and Triggers with PTZ Cameras
Joined: 5/6/2020(UTC) Posts: 4  Location: EDEN PRAIRIE
I have 2 PTZ cameras with multiple inputs at specific PTZ locations. I'd like to set up a shortcut / trigger that would 1. On pressing the shortcut key, actually a StreamDeck key, to put Camera2:PTZ-1 location into the output window. That works. 2. 5 seconds after C2:PTZ-1 goes to output window, send Camera1:PTZ-1 location into the output window. I've set this up this trigger on C2:PTZ-1 input as Trigger Function Input Duration Delay OnTransitionIn Merge C1:PTZ-1 500 5000
This isn't working. Shouldn't C1:PTZ-1 go to the output window 5 seconds after the C2:PTZ-1 goes to the output window?
Cameras 1 & 2: PTZ using Ethernet control RTSPUDP rtsp://192.168.1.21 RTSPUDP rtsp://192.168.1.22
I have no issues setting up multiple (over 10) PTZ locations for each PTZ Camera as inputs. I've set up multiple shortcut actions using a single keyboard key / standard keyboard shortcuts: move C1:PTZ-3 to output, remove overlay3, add overlay 2 Now I'm trying to use StreamDeck to put C2:PTZ-1 to output and use a trigger on C2:PTZ-1 to switch to C1:PTZ-1 Is there something I'm missing about trigger functionality and trying to use use 2 cameras in a shortcut / trigger combination with OnTransitionIn?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
