Bruce27
#1 Posted : Tuesday, July 19, 2022 1:36:03 AM(UTC)
Bruce27
South Africa
I have vMix HD and would like to use a 4K camera with it. My intention is to use vMix to select a portion of the 4K input not larger than 1080p, and then to output that picture using vMix. The output stream will be HD size (1080p). The idea is that using the 4K input will give me some zooming/panning/tilting capability without having to physically zoom the camera or its lens.
I presume that this would be possible using vMix 4K, but I only have vMix HD. I would love to know if this would be possible.
Thank you!
paco3346
#2 Posted : Tuesday, July 19, 2022 1:42:52 AM(UTC)
paco3346
Yes, this will work. The vMix license only refers to the project resolution, not any input resolutions.
thanks 1 user thanked paco3346 for this useful post.
Bruce27 on 7/19/2022(UTC)
Bruce27
#3 Posted : Tuesday, July 19, 2022 4:18:02 AM(UTC)
Bruce27
South Africa
Thank you, Paco, that is very helpful.
#4 Posted : Tuesday, July 19, 2022 8:42:07 PM(UTC)
@ Bruce27
vMix HD does not support 4K camera Inputs, you need vMix 4K or above for that.
Bruce27
#5 Posted : Wednesday, July 20, 2022 12:01:25 AM(UTC)
Bruce27
South Africa
Thanks for your reply, Ice — though I am now uncertain what the situation is!
I appreciate the help, but the replies from Paco and Ice contradict one another! Which is correct?
Can anyone shed any further light on the matter?
vmixgreg
#6 Posted : Wednesday, July 20, 2022 8:07:24 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 19 time(s) in 18 post(s)
Hi Bruce
You cannot use a 4K camera in vMix HD.
If you attempt this, an error message will pop-up saying you need to upgrade to a higher edition of vMix
Similarly, you cannot use an HD camera with the FREE vMix Basic or vMix SD editions (which have subsequently been removed from the vMix website a few years ago because of the confusion it was causing and the fact that so few people have or use SD cameras anymore).
With vMix 4K and above, you can use a 4K Camera in a 1080p project as per your described intentions of using "areas of interest" within the 4K Image and not lose any resolution when you zoom into the image up to 75%.
I hope that helps to clarify.
vMix Greg
paco3346
#7 Posted : Thursday, July 21, 2022 12:34:05 AM(UTC)
paco3346
I stand corrected. Thanks for the clarification everyone.
Bruce27 on 7/21/2022(UTC)
Bruce27
#8 Posted : Thursday, July 21, 2022 1:46:38 AM(UTC)
Bruce27
South Africa
Thank you, Greg for the clarification. That is very straightforward and easy to understand.
Bruce
