rambouzi
#1 Posted : Tuesday, July 12, 2022 2:48:18 PM(UTC)
rambouzi
Netherlands
I use the build in vMix web-browser to capture live streams or video's that can not be downloaded. I use this because the video quality is much better than capturing from the pc screen. But the audio isn't sync.
I need to forward the audio in time to sync it, but I cant travel to the future jet, so that is not an option. So i need to delay the video a bit. But that option is grayed out. So I did get it, kind of, sync by using a complex construction with NDI. But this is not a workable solution.
So is this a bug? Why can't I delay the video of the browser? And why is it not sync in the first place?
Any help is appreciated.
rambouzi
#2 Posted : Tuesday, July 19, 2022 3:27:24 AM(UTC)
rambouzi
Netherlands
Thank you savage693 for your reply.
But non of this is the case. It’s on a fast powerful pc, with update drivers and so on. The stream is sync on the same pc when opened in Chrome. The output is with a Blackmagic card that is perfectly sync when playing video’s in vMix. It’s just the browser that is giving this issue.
I will do some more tests and try on other systems.
Thanks!
