Joined: 6/6/2016(UTC) Posts: 19   Location: The Netherlands
I use the build in vMix web-browser to capture live streams or video's that can not be downloaded. I use this because the video quality is much better than capturing from the pc screen. But the audio isn't sync.
I need to forward the audio in time to sync it, but I cant travel to the future jet, so that is not an option. So i need to delay the video a bit. But that option is grayed out. So I did get it, kind of, sync by using a complex construction with NDI. But this is not a workable solution.
So is this a bug? Why can't I delay the video of the browser? And why is it not sync in the first place?
Any help is appreciated.
Thank you savage693 for your reply.
But non of this is the case. It’s on a fast powerful pc, with update drivers and so on. The stream is sync on the same pc when opened in Chrome. The output is with a Blackmagic card that is perfectly sync when playing video’s in vMix. It’s just the browser that is giving this issue.
I will do some more tests and try on other systems.
Thanks!
