gregboy12
#1 Posted : Sunday, June 22, 2014 8:57:11 AM(UTC)
gregboy12
Looks like i might have fixed the problem with the blue screen admin but i now have another problem and opened a new thread just in case others were having the same as me,
So vmix doesnt recognise my capture card (Elgato Game Capture HD) so i use xSplit and then on vmix i go to capture and select xSplit, The only problem im having is that when it loads the video is perfect but the sound lets off an all might screech, i was wondering what setting on the audio side i would have to do to fix this? I have done it already but i cant remember the setting i did so it is do'able.
gregboy12
#2 Posted : Sunday, June 22, 2014 9:27:29 AM(UTC)
gregboy12
Ok scratch that ive fixed it, Now last problem is with Vmixsocial, i install it correctly but the only problem im having is when i load it i get this error: http://prntscr.com/3v1ccl
ANY IDEAS?
#3 Posted : Sunday, June 22, 2014 10:00:30 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Looks like your config file is corrupt.
Try deleting everything in this folder:
C:\Users\username\AppData\Local\vMixSocial
(Replace username with your username).
If that doesn't work, reinstall vMix Social.
gregboy12
#4 Posted : Sunday, June 22, 2014 10:07:00 AM(UTC)
gregboy12
Hi Martin
Thanks for the quick reply mate really appreciated
So i went to the app data folder and there was nothing there for vmix social, there is a vmix folder there but im assuming thats to do with the vmix program and not the vmix social app, so i have tried to uninstall it which i did and reinstalled it and still getting the same error
gregboy12
#5 Posted : Sunday, June 22, 2014 11:16:40 AM(UTC)
gregboy12
anyone?
gregboy12
#6 Posted : Sunday, June 22, 2014 11:29:37 AM(UTC)
gregboy12
When i finally fix that now i get this error!
http://prntscr.com/3v2cbc
Ive come to the conclusion that this program is way to buggy, If it accepts my capture card in the future i will revisit the software but right now ill stick with xsplit as its far less buggy and actually recognises my capture card
#7 Posted : Sunday, June 22, 2014 6:25:39 PM(UTC)
Hi Greg,
To be honest, it looks like there are some issues with your computer setup as these bugs have not been seen before.
In particular, that latest error means either you don't have a sound card installed, or there is a problem with the sound card.
A sound card is required in order to use vMix.
