asnplus
#1 Posted : Saturday, June 21, 2014 3:05:10 PM(UTC)
asnplus
Hey, there aren't any timer titles in the vMix 12 pack. What happened to them?
#2 Posted : Saturday, June 21, 2014 6:02:22 PM(UTC)
My guess is that since any text field can be set up as a timer, it is a somewhat redundant title category. (I don't know why the tab is still there)
And to boot, with the title designer you can make your own custom title overlays to accommodate your specific needs.
asnplus
#3 Posted : Sunday, June 22, 2014 4:19:01 PM(UTC)
asnplus
So if I bring my clock design over, how do I get the time to just display minutes and seconds instead of the full complement?
krassesPferd
#4 Posted : Sunday, June 22, 2014 7:06:13 PM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
You have to select "mm:ss" in the dropdown timer-menu instead of "hh:mm:ss"
asnplus
#5 Posted : Sunday, June 22, 2014 9:24:18 PM(UTC)
asnplus
, but here is the next problem. I want to set the timer field on the homemade template and control it with shortcuts. How do I expedite that module?
krassesPferd
#6 Posted : Monday, June 23, 2014 4:39:28 AM(UTC)
krassesPferd
Firstly you have to open the Settings and then the "Shortcuts"-Tab. There you create a new shortcut and select a key for the action. After that you select in the "Function"-dropdown "StartCountdown", "PauseCountdown" or whatever you want to do by pressing that key. As Input you set your title and as "text" you choose normally "title" or "message" (the text field, your countdown is in)
asnplus
#7 Posted : Monday, June 23, 2014 5:42:48 AM(UTC)
asnplus
Ok. Did that. However, it still shows hh:mm:ss in the field. How do I show just mm:ss?
krassesPferd
#8 Posted : Monday, June 23, 2014 6:16:00 AM(UTC)
krassesPferd
You set this in the countdown settings. (right-click on the titles input window, "title editor", then click on the "settings" button next to the play/pause/stop buttons. So you get into the countdown settings.) There is a dropdown called "display format". There you select mm:ss
thanks 1 user thanked krassesPferd for this useful post.
asnplus on 6/23/2014(UTC)
asnplus
#9 Posted : Monday, June 23, 2014 11:58:10 AM(UTC)
asnplus
THAT'S. What the heck I was doing wrong. Thank you much.
