june
#1 Posted : Thursday, June 19, 2014 8:52:16 AM(UTC)
june
Vmix does not find my camera
Hello, I am new on this software and I vmix do not find my camera, I connected it with a cable HDMI.
I tried with other device with the same method but without result.
I have to look at the video on YouTube with the tuto but being French with bad English, I maybe missed something..
Thank you
TVIason
#2 Posted : Thursday, June 19, 2014 9:04:03 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Wat capture card do hou use?
june
#3 Posted : Thursday, June 19, 2014 9:10:34 AM(UTC)
june
I use it not I am just connected by a cable Hdmi or usb, while following the forum I understood that it was necessary to use a card capture.
One is absolutely needed?
vmixsupport
#4 Posted : Thursday, June 19, 2014 8:46:35 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Yes you must plug your camera into a capture card in order to add it into vMix. See our Supported Hardware page for recommended capture hardware:
http://www.vmix.com.au/supported-hardware.aspx
