tluttrell
#1 Posted : Monday, July 11, 2022 5:40:27 AM(UTC)
tluttrell
I have inserted 3 camera inputs for cameras connected to a PTZ camera controller system. They are listed in the vMix camera list as Decklink Duo 1, Decklink Duo 2 and Decklink Mini Recorder 5. I don't know why these labels are the way they are as I didn't do the initial set up of the cameras, controller or their connectivity in vMix. I am noticing the camera views in vMix as I move the joystick on the camera controller. The Decklink Duo 2 camera is also adjusting when I select the Decklink Mini Recorder 5 and manipulate it with the joystick so they move and are zooming in and out together. Is this likely an issue with the controller instead of the way the cameras have been set up in vMix?
Also, is the way these cameras are setup/labeled in vMix a potential problem?
zenvideo
#2 Posted : Monday, July 11, 2022 10:19:49 PM(UTC)
zenvideo
What you are seeing in vMix is the device names of the various (Decklink) video capture card inputs. As to what video appears on those inputs depends on what is physically connected to the input sockets.
Yes, it is likely to be an issue with the controller. What happens with the cameras when you do the same thing but without vMix running? (Obviously you'll have to look to see if the actual cameras move unless you can monitor the outputs some other way outside of vMix.)
Not really - you're seeing the name that's allocated by default but you can edit it in the Configuration settings for each of those inputs. (Gear-wheel icon)
tluttrell on 7/12/2022(UTC)
tluttrell
#3 Posted : Tuesday, July 12, 2022 12:31:27 PM(UTC)
tluttrell
Thank you very much for your response. It is very helpful. When the installation technicians arrive tomorrow I will be bringing the camera control problem to their attention.
