Ash
#1 Posted : Saturday, July 2, 2022 10:35:28 AM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi
I have been using the Podcaster Pro 1 for some time and recently upgraded the firmware and Rode Central and ASIO drivers.
Have found that vMix will not shut down if the Podcaster Pro is connected to the USB port. I have to force a shutdown using Task Manager.
Unplug the USB port retry and vMix shuts down as per normal.
The Podcaster is set up as per the Knowledge Base https://www.vmix.com/kno...ter-pro-to-vmix-via-asio
I have 2 of them and this occurs on the 2 different systems (all are Windows 10 Pro).
Has anyone else had this issue and if so is there a solution?
Regards
Ash
roverradio
#2 Posted : Monday, July 4, 2022 11:01:38 AM(UTC)
roverradio
Yes, this seems to happen when using ASIO drivers with Rocecaster Pro v1. Doesn't happen if using the non-ASIO drivers, but of course you lose some functionality that way.
Have a v2, but haven't tested it out yet.
pob
#3 Posted : Saturday, August 6, 2022 4:29:15 PM(UTC)
pob
Sweden
The same problem for me, as soon as i add just one sound source from the Rodecaster Pro v1 vmix hangs at shutdown
tcaldwell
#4 Posted : Wednesday, May 6, 2026 5:30:42 AM(UTC)
tcaldwell
I have a procaster II and using asio for audio. Works well but every time i close vmix.. it hangs and causes my show to be lost. If I use task manager to end vmix I lose my vmix show info. I have a backup but the original show file goes down to 22K and I loose anything I had saved. Anyone find a solution other than unplug the usb cable?
