andreypetr
#1 Posted : Thursday, June 30, 2022 2:38:11 AM(UTC)
andreypetr
Hello.
I dont know why simple TXT datasources have only 1 line. I guess you could make them into CSV, but then the comma becomes a delimiter. Can we get multiple lines for text files when importing them as datasources?
mavik
#2 Posted : Thursday, June 30, 2022 11:38:12 PM(UTC)
mavik
A txt datasource is really single line. But there is nothing that hinders you to add a few lines and save it as a csv file to get multi line for titles etc. Technically almost no difference. Just more wording.
RichDanby
#3 Posted : Friday, July 1, 2022 1:30:12 AM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
Yes, save the file as .csv and wrap each line in quotation marks " to avoid commas being an issue (then quotation marks might become an issue but they are rarer!)
The option to separate each new line into a new row would be good for TXT sources, but the workaround isn't too difficult.
