.TXT datasource second line?
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hello. I dont know why simple TXT datasources have only 1 line. I guess you could make them into CSV, but then the comma becomes a delimiter. Can we get multiple lines for text files when importing them as datasources?
A txt datasource is really single line. But there is nothing that hinders you to add a few lines and save it as a csv file to get multi line for titles etc. Technically almost no difference. Just more wording.
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
Yes, save the file as .csv and wrap each line in quotation marks " to avoid commas being an issue (then quotation marks might become an issue but they are rarer!)
The option to separate each new line into a new row would be good for TXT sources, but the workaround isn't too difficult.
