Joined: 10/9/2021(UTC) Posts: 4  Location: Paraná Thanks: 1 times
Hello guys, We are sporadically having a problem with vMix, I put 3 logs of this problem and 1 live link where we can see the problem happening. Basically when this happens, the first thing we notice is the delay in opening vMix and when opening the video it's already freezing as if it were low fps, even closing and opening the program again, it's no use =/ it's necessary to restart the computer so that this be corrected. If anyone can help us fix it, we'd appreciate it. Live link with problem: https://youtu.be/V17WPw7kcYsLogs: https://docs.google.com/document...MWf4iow/edit?usp=sharing
Joined: 9/10/2015(UTC) Posts: 138  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
Can you share other details such as what hardware you're on?
Originally Posted by: paco3346  Can you share other details such as what hardware you're on? Windows 10 Pro AMD Ryzen 5 3600 6-Core Processor 3.60 GHz 16,0 GB raam Nvidia GeForce GTX 1050ti SSD 120gb
Joined: 3/7/2012(UTC) Posts: 2,673  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ midia.4ieq
D3DRender errors are GPU related so you may want to make sure your drivers are up-to-date, but the issue could also be multifaceted and/or indicate overworked or failing hardware. I would recommend sending an email to vMix Support and they may be able to investigate more thoroughly.
