vmix logs - High Importance
Joined: 5/30/2022(UTC) Posts: 4  Location: Nellore Was thanked: 1 time(s) in 1 post(s)
Dear Team,
Requires logs for vmix. what ever played in vmix required logs. as of not vmix does not generating any logs which will impact the valued customers.
whatever we are playing in video list and send out from vmix, requires logs for it. Please insert this feature in next update.
Regards John.
Originally Posted by: john.wesley  Dear Team, Requires logs for vmix. what ever played in vmix required logs. as of not vmix does not generating any logs which will impact the valued customers. whatever we are playing in video list and send out from vmix, requires logs for it. Please insert this feature in next update. Regards John. If urgent and really needed make script to check what is active , get details of input mentioned in active , write info to txt file with timestamp
Can you please provide the script. I just want the logs for content added in video list and played from vmix. It is help us to track the commercial ads in billing.
Regards John.
@doggy @Nikosman88
Your links are not valid. Please check once and share latest one.
Regards John.
 1 user thanked john.wesley for this useful post.
Regards John. Links work fine here
Links ok for me too.Vmix logger runs outside of vmix as powershell file and gives more details things for example like when you overlay it will be write in log As script inside vmix you can also use this https://forums.vmix.com/...or-commercials#post99914it works ok
