john.wesley
#1 Posted : Monday, May 30, 2022 9:41:29 PM(UTC)
john.wesley
India
Dear Team,
Requires logs for vmix. what ever played in vmix required logs. as of not vmix does not generating any logs which will impact the valued customers.
whatever we are playing in video list and send out from vmix, requires logs for it. Please insert this feature in next update.
Regards
John.
#2 Posted : Monday, May 30, 2022 9:55:25 PM(UTC)
Originally Posted by: john.wesley Go to Quoted Post
Dear Team,
Regards
John.
If urgent and really needed make script to check what is active , get details of input mentioned in active , write info to txt file with timestamp
john.wesley
#3 Posted : Tuesday, May 31, 2022 5:42:19 PM(UTC)
john.wesley
India
Can you please provide the script. I just want the logs for content added in video list and played from vmix. It is help us to track the commercial ads in billing.
Regards
John.
nikosman88
#4 Posted : Thursday, June 2, 2022 5:25:33 PM(UTC)
nikosman88
Greece
Hello see this video https://www.facebook.com...videos/1022518751813921/ and this script https://gist.github.com/...8yF3Ff0OM453gHUSAcRa33X0
A good solution for live shows i think as it keeps logs.
For non live shows i am using vmix scheduler https://forums.vmix.com/...ler---vMixScheduler-Fork it doesnt keep logs in a special log file but if you save the lists you load (it saves xml file) you can have log of what you played via list in any specific time/date you did it
#5 Posted : Thursday, June 2, 2022 7:12:27 PM(UTC)
Here is another bit of code i found : https://www.dropbox.com/...vMix-LoggerV2.1.ps1?dl=0
john.wesley
#6 Posted : Thursday, June 2, 2022 7:19:30 PM(UTC)
john.wesley
India
@doggy @Nikosman88
Your links are not valid. Please check once and share latest one.
Regards
John.
thanks 1 user thanked john.wesley for this useful post.
nikosman88 on 6/2/2022(UTC)
#7 Posted : Thursday, June 2, 2022 7:45:44 PM(UTC)
@doggy @Nikosman88
Regards
John.
Links work fine here
nikosman88
#8 Posted : Thursday, June 2, 2022 8:45:09 PM(UTC)
nikosman88
Greece
Links ok for me too.Vmix logger runs outside of vmix as powershell file and gives more details things for example like when you overlay it will be write in log
As script inside vmix you can also use this https://forums.vmix.com/...or-commercials#post99914
it works ok
