Feature Requests
Title tally mark on title input
When right-clicking on a title input that has a number of items, I think it would be useful to have a small tally mark or highlight next to the one that is currently selected. This would be especially useful if you need to have your input windows quite small and you cannot read what the lower-third name is that is currently being displayed.
Thanks!
Phil.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks!
Phil. Confused : right click means go into title editor , do you mean a mark for which title text item one is editing ? Lower third name is also written at top of editor window and not related to the size of the input windows (ie big enough). Else bigger monitors come to mind and renaming the title inputs with shorter easier readable names . Lower thirds are mostly overlayed as such they have the indication (green) which overlay number they are active on.
 Title.jpg (129kb) downloaded 0 time(s).Attached should be an example image. You will see an example list of names when you right-click on the input window. I was suggesting a check mark next to which one was the current 'live' one. I realise a large / higher resolution monitor can help, but this is not always possible if you need to run off a laptop for example or is space is tight.
Would sugest using datasources instead of the title editor to use a list of data. Can always leave the datasource manager window open, place it wherever you want, have larger/longer overview and it will indicate the current selection
Feature Requests
