Joined: 9/9/2020(UTC) Posts: 9  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello all, Just found out that when you have an unavailable path (eg to a drive letter that doesn't exist) the recording starts without warning. I had a preset from another pc that had the drive letter F:/. The recording format was in .ts. No warnings during the recording. After the event I found out that the path was wrong and couldn't find the recording. Is there any possibility of finding the file on a 'temp' folder. (I've searched already the user temp folder under AppData/Temp. At least Vmix should warn that the path was invalid.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
The recording goes to whatever is set in Settings -> Recording in vMix if it can't find the folder. Failing that it will go to Documents\vMixStorage so check either of those places.
Thank you for your reply. Already found it. Should pop up a warning though if the path is invalid, in order to avoid heart attacks :)
 1 user thanked gas75 for this useful post.
Joined: 5/3/2020(UTC) Views messages in topic : 6  Location: Cheraw
Originally Posted by: gas75  Thank you for your reply. Already found it. Should pop up a warning though if the path is invalid, in order to avoid heart attacks :) Where did you find yours? I am having the same problem.
Hi donebrasko, as Admin kindly replied to me the path is in your Documents folder under \vMixStorage Originally Posted by: admin  The recording goes to whatever is set in Settings -> Recording in vMix if it can't find the folder. Failing that it will go to Documents\vMixStorage so check either of those places. Hope this helps
