gas75
#1 Posted : Sunday, November 14, 2021 7:23:13 AM(UTC)
gas75
Greece
Hello all,
Just found out that when you have an unavailable path (eg to a drive letter that doesn't exist) the recording starts without warning. I had a preset from another pc that had the drive letter F:/. The recording format was in .ts. No warnings during the recording. After the event I found out that the path was wrong and couldn't find the recording. Is there any possibility of finding the file on a 'temp' folder. (I've searched already the user temp folder under AppData/Temp.
At least Vmix should warn that the path was invalid.
#2 Posted : Sunday, November 14, 2021 12:37:22 PM(UTC)
The recording goes to whatever is set in Settings -> Recording in vMix if it can't find the folder.
Failing that it will go to Documents\vMixStorage so check either of those places.
gas75
#3 Posted : Monday, November 15, 2021 8:52:40 PM(UTC)
gas75
Greece
Thank you for your reply. Already found it. Should pop up a warning though if the path is invalid, in order to avoid heart attacks :)
thanks 1 user thanked gas75 for this useful post.
Peter1000 on 11/15/2021(UTC)
donebrasko
#4 Posted : Saturday, May 28, 2022 1:29:55 AM(UTC)
donebrasko
Where did you find yours? I am having the same problem.
gas75
#5 Posted : Saturday, May 28, 2022 5:28:41 PM(UTC)
gas75
Greece
Hi donebrasko,
as Admin kindly replied to me the path is in your Documents folder under \vMixStorage
Hope this helps
