light n images
#1 Posted : Friday, October 28, 2011 3:21:23 AM(UTC)
light n images
Is it possible to combine Black Magic input and DV input ?
When I select Blackmagic output, vmix says 'filter combination failure' how to get output through Blackmagic rendering ?
BTW I am using free trial is there any limitations ?
If I buy Basic HD will it be possible to output through Blackmagic Intensity ?
Your software is a marvel and I like the way it works. I am a small time producer and I will be happy with yours.
thanks
#2 Posted : Friday, October 28, 2011 7:12:03 AM(UTC)
Was thanked: 4688 time(s) in 1611 post(s)
When the error appears please click "Send Error Report" so we can look into it further.
light n images
#3 Posted : Saturday, October 29, 2011 4:21:44 AM(UTC)
light n images
Hi Martin,
Pl take time to answer all my querries.
I am eager about the output source.
thanks
Kirubagaran @ light n images
#4 Posted : Sunday, October 30, 2011 12:52:41 AM(UTC)
To explain the BlackMagic output, you need a separate card just for output.
The Intensity card only supports inpur or output but not both at the same time.
Mauro Cesar
#5 Posted : Wednesday, November 2, 2011 6:07:51 PM(UTC)
Mauro Cesar
Blackmagic Intensity Pro how many I use a motherboard? I will replace four "Intensity Shuttle" and buy Intensiy Pro or Osprey.
Sincerely,
Mauro
