Joined: 10/28/2011(UTC) Posts: 2 Location: chennai india
Hi, Is it possible to combine Black Magic input and DV input ?
When I select Blackmagic output, vmix says 'filter combination failure' how to get output through Blackmagic rendering ?
BTW I am using free trial is there any limitations ?
If I buy Basic HD will it be possible to output through Blackmagic Intensity ?
Your software is a marvel and I like the way it works. I am a small time producer and I will be happy with yours.
thanks
When the error appears please click "Send Error Report" so we can look into it further.
Martin vMix
Hi Martin,
Pl take time to answer all my querries.
I am eager about the output source.
thanks Kirubagaran @ light n images
To explain the BlackMagic output, you need a separate card just for output. The Intensity card only supports inpur or output but not both at the same time.
Blackmagic Intensity Pro how many I use a motherboard? I will replace four "Intensity Shuttle" and buy Intensiy Pro or Osprey. Sincerely, Mauro
