Micro stutters/dropped frames
We have what should be a very powerful PC but are experiencing frequent stutters which are likely due to dropped frames. We'd love any feedback about things we could tune or investigate to address this issue. CPU: i7-9700f@3GHz (8 cores) Memory: 16GB Graphics: NVidia Geforce GTX 1660 Super (1830 MHz, Total avail graphic mem: 14GB, Dedicated Video mem: 6144MB GDDR6, PCI Express x4 Gen 3, Shared System Memory 8151MB) Capture: Blackmagic DeckLink SDI 4K I ran stats during our last stream:  DropStats.jpg (87kb) downloaded 10 time(s).I'm not clear on how to interpret these stats to identify our problem. Do you have any suggestions on things we could investigate?
Does anyone have suggestions as to what we could investigate here?
I dont have any suggestion about this thing
Joined: 2/9/2021(UTC) Posts: 35  Location: Oslo Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
I'm not an expert, just a fresh amateur. Judging solely by the statistics, it might indicate your CPU/graphics card can't reliably process the frames from the Decklink card quickly enough. The frame interval numbers indicate that your camera might be running at 60FPS. Is that right? (21 11 18 16 -- 1000/number gives FPS value) That is also a lot of variation between frames - between 50 and 100 frames per second. At a best, amateur guess your computer might be having trouble keeping up with a 60 FPS source? If your camera is running at 60FPS, try to bring it down to 30FPS to see if it stabilises. If it's not set to 60 FPS, well, I've obviously misread the entire thing. Also make sure that both your camera and your VMIX have the same framerate setting or your computer will be working unnecessarily hard to convert one to the other. Most stream platforms can't render 60FPS in live streams at any rate. (Places like Vimeo will show the 60FPS in archived video, though) Also check the bitrate of the video input isn't unnecessarily high. I wouldn't do 4K/30 on that rig, especially if you're getting full 4K bitrate video in. (~160mbit) Set up a test stream for an hour with a high-bitrate video with a lot of motion, on a loop. Like this: http://bbb3d.renderfarming.net/Check in from time to time and see how your CPU and GPU performance is doing. Take note if performance is stable. Again, just an amateur here, but hopefully it gives you some leads to chase down. If nothing else to rule them out. :)
This maybe a little late but I was having same problem. I went into settings under "performance" and clicked on the button called "high input performance mode" this works perfectly and lets my gpu do all the rendering. I have an i9-13900HX cpu with 64 gig ram, and a nvidia geforce rtx 4090 and was still getting the stuttering.
this resolved my issue. it works for gpu's with 3 gig or more and your card has 6 gig so it should work for you as well.
Just a follow-up. I eventually resolved the issue by reinstalling Windows and all our applications on a fresh storage volume. It was a lot of work, but it's working smoothly now.
So it wasn't a hardware problem - it was a Windows issue - perhaps a corrupted file system.
Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: Biff  This maybe a little late but I was having same problem. I went into settings under "performance" and clicked on the button called "high input performance mode" this works perfectly and lets my gpu do all the rendering. I have an i9-13900HX cpu with 64 gig ram, and a nvidia geforce rtx 4090 and was still getting the stuttering.
Take a look at this page, it might be worth using resizable bar and disabling high performance mode: Resizable Bar
