VU Meters could do with improving
Joined: 5/16/2022(UTC) Posts: 7  Location: Oxford Was thanked: 2 time(s) in 2 post(s)
Having a sound engineering background, I find the screen-side VU meters leave a lot to be desired. They are too fast, not segmented enough, a bit thin and don't deliver any meaningful accuracy.
So for monitoring output sound, they're really not that useable.
A replication of LED meters, with a fading residual peak level segment would be a huge improvement.
Would greatly appreciate this being attended to.
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
I use Youlean loudness meter for monitoring my output e.g. when streaming. You can run it as a plugin in the audio settings
Originally Posted by: Chris Daum  I use Youlean loudness meter for monitoring my output e.g. when streaming. You can run it as a plugin in the audio settings Thanks for that. Can it be left open as a window?
yes, it opens in a separate window and can be left open
Originally Posted by: Chris Daum  yes, it opens in a separate window and can be left open Great, I've just purchased it, so will install in the next few days. Thanks for the tip.
