richardnottv
#1 Posted : Friday, May 13, 2022 1:36:16 AM(UTC)
richardnottv
That would be useful and also include the ability to toggle MIDI keypad activators from scripts.
So many items are partially implemented and a lot are missing implementation examples.
#2 Posted : Friday, May 13, 2022 2:25:33 AM(UTC)
Originally Posted by: SPbAG Go to Quoted Post
Please help. How to organize waiting for a keypress? And depending on whether the key is pressed or not, to fulfill one or another condition?
if ... 'key press
else 'key not press
this woudld be vb.net related (usable within vMix scripting)
like this
SPbAG
#3 Posted : Friday, May 13, 2022 3:00:10 AM(UTC)
SPbAG
Russian Federation
how can this be used in vmix scripts?
SPbAG
#4 Posted : Friday, May 13, 2022 3:14:30 AM(UTC)
SPbAG
Russian Federation
The goal is for the script function to be executed while the key is pressed. The key was released - the function loop exited
#5 Posted : Friday, May 13, 2022 4:18:56 AM(UTC)
sorry no idea (my mistake) , more used byme in external scripts
Have you looked through this forum ?
https://forums.vmix.com/posts/m29757-vMix-18--Send-hotkey-and-API-commands-from-vMix#post29757 for example
Salvatore
#6 Posted : Friday, May 13, 2022 5:07:48 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
If you use a Streamdeck try this:
Add a shortcut, Select the „Streamdeck Button down“ Key with the „ScriptStartDynamic“-Function in combination with loop
Code:
do while true
API.Function("your Function")
loop
Add a second shortcut, Select the „Streamdeck Button up“ Key with your end Function
thanks 1 user thanked Salvatore for this useful post.
SPbAG on 5/13/2022(UTC)
