How to make a script to determine if a key is pressed or not?
That would be useful and also include the ability to toggle MIDI keypad activators from scripts.
So many items are partially implemented and a lot are missing implementation examples.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: SPbAG  Please help. How to organize waiting for a keypress? And depending on whether the key is pressed or not, to fulfill one or another condition?
if ... 'key press
else 'key not press ... this woudld be vb.net related (usable within vMix scripting) like this
Joined: 5/12/2022(UTC) Posts: 4  Location: Saints-Petersburg Thanks: 1 times
how can this be used in vmix scripts?
The goal is for the script function to be executed while the key is pressed. The key was released - the function loop exited
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
If you use a Streamdeck try this: Add a shortcut, Select the „Streamdeck Button down“ Key with the „ScriptStartDynamic“-Function in combination with loop Code:do while true
API.Function("your Function")
loop
Add a second shortcut, Select the „Streamdeck Button up“ Key with your end Function
 1 user thanked Salvatore for this useful post.
