GT
Data Source Text
Joined: 10/21/2021(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
Hi everbody,
I have a Txt-File that includes several Information coming from an external Device.
Example:
Zeit1=05:06:30 Zeit2=03:25:32 Zeit3=02:25:30 etc.
Is there a posiblity to use that TXT-File within GT, so that i can use the different values as separate Variables. Or is it possible to cut for example the first five letters, use the next 8 charcters und ignore the rest of the file?
best regards Thomas
Example:
best regards Thomas to cut out you 5 letters put the data in a hidden textbox in your title (add it in the title) , and let a script read the content , strip that part and put the result in the displaying textbox
Thanx a lot.
In the last 2 months I couldn't take care of the problem, but with your tip I found the solution. Thanks for all of your contributions here in the forum, I've learned a lot.
What is the solution? I am now facing a similar issue.
Your are so kind. Just today I was watching videos of VMix scripting.
Thanks again
GT
Data Source Text
